Thread: White-ish stains on pool walls, possible remedies and chemical interaction
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    I began getting white-ish stains or scaling on the walls of my pool some weeks ago. I called the pool manufacturer who sent their fiberglass specialist out to assess the situation. He recommended using an anti-scaling product to help mitigate the condition along with a product called "Cell Protect".
    Can anyone tell me how my "routine" chemical levels will be affected by the use of these other chemicals? I just don't know what to expect.
    Thanks much.
    Barry
    Barry, Central GA
    15X36 IG 14,200 gal fiberglass pool. Hayward Sand Filter with 1 HP Hayward SUPER PUMP. Pentaire "Kreepy Krawly Robotic Cleaner
    e-mail: oso49@cox.net
    Re: White-ish stains on pool walls, possible remedies and chemical interaction
    You should post a complete set of water test results.
    I strongly suspect you have calcium scaling. We recommend not using those additional chemicals, except in extreme situations. Normally scaling can be prevented by adjusting your levels appropriately. How you do that depends on what your levels are now.
    bear31088's Avatar
    Dec 2013
    Warner Robins, GA
    46
    OK, thanks. The guy half emptied the pool and it's filling now. I'm currently at work, but I'll get the test results posted as soon as I get home.
    Thanks, again!
    Barry, Central GA
