Thread: Repair of Gunite Stairs
    Have a couple of small repairs I need to make on the gunite stairs. One where the Kreepy grinded into them over the years and another 3" x 3" section where a thin sliver of gunite came loose. Leslies recommended I use non-sanded grout since I could pretty much match the color of the gunite. They also suggested e-z patch pool plaster but the color would not match nearly as well. Has anyone used grout the patch a section of gunite? Thanks for the help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Repair of Gunite Stairs
    I don't know, but hopefully someone can weigh in on this for you. Just giving it a before it gets buried.
    Essential Links:
    JoshU's Avatar
    New Orleans, LA
    543
    I've used E-Z Patch many times with good success. The manufacturer offers videos on their website. If the rough area on the steps is in the 90 degree angle (or so) of the step where the horizontal surface meets the vertical surface it may be more difficult to get the patch to hold especially if it is small areas needing to be patched. I've never used grout for this.
    What color is your plaster?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Thanks Josh, that was quick and helpful.
    Essential Links:
    Thanks for the help guys. Pool stairs are an off white color so the E-Z patch will probably not match well. I've watched the videos for E-Z patch and it does look fairly easy to use (albeit a little pricey). That may be my best bet though. Thanks again for the help (and for bumping my post)!
    Quote Originally Posted by JoshU View Post
