Thread: Calcium in Plaster Pool Refill
    Jul 2011
    Austin, TX
    61
    Last week I did a drain and fill on my 16,000g plaster pool (it needed an acid-wash and tile cleaning). I refilled it with our local tap water and the water chemistry is doing great - I'm moving to the BBB method.
    The last two items I have to balance are Calcium and Borates. The Calcium is 175. I've been reading that others have waited a month before adjusting CH, but those situations were for new pools. For a refill, should I wait a month or go ahead and balance it out?
    Thanks to everyone for BBB method and support!
    FC=3
    CC=0
    TA=120
    PH=7.5
    CA=40
    CH=175
    38,290
    Re: Calcium in Plaster Pool Refill
    Is your signature right? Describes a different pool.
    You should adjust the CH now. Also realize borates are optional.
    Jul 2011
    Austin, TX
    61
    Thanks for the help. I will start slowly.
    I tried to hide the signature - I just updated it.
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
