Thread: Expansion Joint caulking/ Sealing
    Would like to know my self I am removing the wood joints in concrete to many splinters ....
    Split from same topic in a different thread. Please post a new question and don't ask one in someone else's thread. Brushpup.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Expansion Joint caulking/ Sealing
    I moved your topic here as per my PM to you. Please expand on your question for answers.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    nothing wrong with removing the wood in expansion joints. If you do it, it's recommended to re-fill the joint with foam backer rod and self leveling caulk. You can google it and get step by step instructions.
    Quote Originally Posted by tommyhernandez View Post
    Divin Dave,
    Have you ever heard of re lasting a pool with out chipping out the plaster first?
    38,290
    Yes, if the old plaster is still well bonded. But I would personally prefer to chip it all out.
    I got a couple of estimates to replaster my pool. One contractor stated, "You pool is 17 years old and has never been replastered. To maintain the integrity of your original pool shell, we would sandblast the old plaster, then apply a bonding agent, then apply a new plaster coat to the bonding agent." He simply refused to chip it out by saying a chip out is for a pool that has been sandblasted a couple of times first and is 20 years or older. The next day another contractor stated: "The only way to get proper bonding on a new plaster coat is to chip it out down to the gunite shell. Whatever you do, DO NOT SANDBLAST THE ORIGINAL OLD PLASTER AND APPLY A NEW PLASTER COAT TO ANY BONDING COAT. IT WILL NOT ADHERE PROPERLY AND YOU WILL BE WASTING YOUR MONEY." Which one of these contractors is telling me the truth?
