Thread: Quick help please!
    new2pools's Avatar
    Hampton Roads/Virginia
    180
    Quick help please!
    Hello!
    Here are my numbers (my FC only went down .5 overnight, night before last so I think I'm good there)
    FC-2.0 (a little low)
    CC-0
    PH-7.5
    T/A-110
    CYA- um, first time I got a reading like this. I could see the dot clearly when the tube was filled completely to the top. This basically means I have nothing helping to keep the chlorine in the water, correct? I have some trichlor-something pucks. Should I add one to the skimmer and see what my reading is after that dissolves?
    Okay, question. With the numbers I've got above, is it safe to swim today? My son is so anxious to get in. (we were away and opened the pool late so no one has been in yet)
    Thanks so much for your help!
    27' Round AGP, 17200 GAL, 2 HP/2 SPD Pump/Cartridge Filter.......BBB!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Quick help please!
    I think your numbers look fine as far as go ahead and swim.
    You'll probably have to add more bleach tonight. You will need to add your CYA/stabilizer to bring it to the 30-50 range, but you can swim today and work on that tomorrow. Use the pool calculator for dosages and the CYA chlorine chart for your appropriate levels.
    With CYA very low and FC around 2 you are good for now.
    One trichlor puck will have little effect on the CYA level. It takes quite a few of them, usually over weeks, to raise the CYA level. As long as you keep the PH from getting too low the trichlor is probably worth using for now.
    new2pools's Avatar
    180
    Thanks so much both of you! My son will be glad to hear it.
    Oh and thanks for the info on the CYA too.
