Thread: Question for TF-100 test kits
    I have used my TF-100 test kits for 2 years already. Is the chemical still good for another year? or I have to order the fresh chemical this year? I don't know how long we can keep the chemical until it is went out.
    - NY Albany ~27000 water
    - In ground Vinyl 18' X 40' X 8' Deep Curved Roman End
    - Pentiar TA 60 Sand Filter
    - Pentair WhisperFlo 1HP Energy Efficient Full-Rated 2-Speed
    - 250K BTU Nat/Elec. Heater
    38,238
    Re: Question for TF-100 test kits
    Depends on how you have stored it ... it all might still be good, but hard to say.
    They are having the annual refill sale through this weekend, so probably a good idea to refresh it for $32 + shipping.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If it has been stored indoors and not in a hot/cold shed or similar, chances are most reagents are still ok. If you haven't replenished the FC components before I would do that at minimum.
    Essential Links:
    Aug 2011
    Cochranville, PA
    228
    Last year I purchased the whole refill kit. I had everything from the year before. This year I found that I only needed the CYA and the FC test. So I dated everything and going to use the older first and if it seems to be testing odd try out the new and toss out what isn't working correctly. I took the leftover money and became a supporter!
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
