Results 1 to 7 of 7
Thread: Cant maintain chlorine at all
    My wife and I have been trying to get the chemicals straight in our pool for the last 4 weeks to no avail. We have been going to the pool center and having the water tested only to be told that everything is fine but the chlorine. WE have shocked till we dropped the pool to no avail. We recently purchased the TF-100 test kit and obtained the following numbers:
    FC: 1.5
    CC: 2
    TC: 3.5
    PH: 7.25
    T/A: 310
    CH: 400
    CYA: 20
    Water Temperature: 82
    We have a 24 foot above ground pool that holds approximately 13,500 gallons of water. We are interested in maintaining our pool with the BBB method.
    Any help to get the water balanced properly would be greatly appreciated. Thanks in advance for your help with this matter.
    Sincerely,
    Mike
    24 Foot AGP
    13,500 Gallon
    Sand Filter
    billyjoeraybob's Avatar
    Apr 2008
    SC Midlands
    50
    Re: Cant maintain chlorine at all
    welcome brother! Become one with the BBB method and listen to the guys and gals here they will get you straight!
    Bill
    18' x 36' Freeform IG Gunite with 7' spa, Super Blue DiamondBrite, Pentair 1.5 hp circulation pump, Pentair 2.0 hp spa booster pump, Pentair Triton II Sand filter, Polaris 280 with booster pump, Pentair Intellichlor IC40 SWCG, Jandy Laars LX 250k btu NG heater, TF-100 test kit from http://www.tftestkits.com/
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Hi Mike, welcome to TFP!
    Your CH is at the high end, and for an AG pool, you really only need 150. I'm guessing you have been shocking with a Calcium-Hypo product?
    Your best bet is shock with bleach. Your 2ppm CC means you have to bring your pool to shock level and hold it there, overnight, till you lose less than 1ppm in FC and your CC are less than .5.
    Having the TF-100 is a great start. Your CYA is a little low which could be part of the reason for your inability to maintain chlorine. So I would add some CYA/stabilizer according to the pool calculator, and get some more bleach in there, up to your shock level, according to the CYA chlorine chart, keeping it in line as you add CYA you need a higher shock level, etc.
    What color is the water?
    11,969
    Also, I forgot to mention it's helpful to post your pool equipment specs in your signature (update it thru your "profile") and also what area you live in as weather conditions can affect water chemistry.
    Because of your low CYA level, you should do most of your shocking in the evening. Try raising FC up to 12 every hour for several hours in the evening each evening until FC doesn't fall more than 1 overnight and CC is 0.5 or lower.
    Longer term you should raise CYA to 30-50 and lower TA.
    Apr 2008
    SC Midlands
    50
    Mike the following link written by JasonLion will give you a detailed rundown of what you need to do . Your problem is not this severe but the process is basically the same turning-your-green-swamp-back-into-a-sparking-oasis-t4147.html
    Bill
    Apr 2008
    SC Midlands
    50
    MandM,
    Just curious if you guys were making any progress. Give us an update when you get a minute.
    Bill
