Results 1 to 9 of 9
Thread: No chlorine in salt water pool
    Sep 2013
    Los Angeles, CA
    32
    After finally getting a hang of keeping my pool in check for about a month I ran into another problem. My chlorine is nearly at zero in my salt water pool. I have my swg running at a 100% (it was running at 30%) but it's still not coming up. Water looks clean. The only other test that's coming out of range is TA which is at 60. A pool store is telling me that fixing TA will solve my chlorine issue, but I can't understand why. My pH is 7.6 by the way.
    Are they correct or do I have something else going on?
    Thanks.
    27K gal, IG pebble, Jandy JEP2.0 VS ePump, Jandy DEV60 filter, Jandy SW with ChemLink C1900, Zodiak MX8 vacuum
    The pool was repiped and new equipment installed Nov 2013.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: No chlorine in salt water pool
    Do you have a reliable test kit to perform your own tests? How's your salt level? Can you post a full set of test results here?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    They are ABSOLUTELY wrong. Do not adjust the TA. You do have something else going on.
    TA does not fix Chlorine. Something is wrong with your SWG unit, or you have something in your pool that is demanding more FC than your cell can generate. If you really want to know what is going on in the pool you really need a proper test kit to find out. If you have one, can you please post a full set of results?
    Essential Links:
    TA around 60 is essentially ideal, changing it would have only a tiny effect, none of it good.
    Often you need to SLAM the pool before the SWG is ready to take over again, though it is impossible to say without a full set of water test results.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Is this a new salt cell or has it recently been cleaned?
    JoshU's Avatar
    New Orleans, LA
    543
    From signature:
    Do you have a ORP controller installed? Is it controlling the chlorine generator's chlorine output?
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Sep 2013
    Los Angeles, CA
    32
    Thank you all for your replies.
    Yes, I use TF-100 kit for my testing. Here are the results from this morning
    FH - 0
    CC - 0
    pH - 7.5
    CH - 350
    TA - 70
    CYA - 70
    Salt - 3200
    My salt cell is about 4 months old. I do have an ORP controller installed. It shows that my ORP is very low. Depending on time of the day it will show 140 (right now) to 280 during the day.
    Because of some work in my yard the pool is covered with tarp since yesterday morning, and even that didn't help chlorine levels to rise.
    At a minimum, you need to SLAM the pool manually, and re-establish normal chlorine levels. Once you have done that, the SWG should be able to take over again. However, it is also possible that there is something wrong with the SWG, though diagnosing that is easier once the pool is back to normal.
    It is normally impossible to get ORP based controllers to work correctly when CYA is that high. For that matter, I don't recommend using ORP based controllers with outdoor residential SWG pools. There tend to be a variety of problems, and standard percentage based control of the SWG is almost always more reliable.
    Sep 2013
    Los Angeles, CA
    32
    Thank you all for your responses. I added chlorine and got it to a normal level. Didn't really SLAM the pool, but the FC is staying consistent for two days now. What I found is that my SW cell is stuck in "reversing" thus not producing chlorine. Got to figure out why, given it's only 4 months old.
