Thread: Booster pump died in less than 3 yrs? I need some helps
    My booster pump (Max-E-Pro 1.5HP) for water feature doesn't seem to work after 2+ yrs of good running. I didn't run or call for any diagnostics but it seems that it doesn't pump water anymore and just makes noises. Is this usually time for replacement (installed in 2011 summer) or something I can fix? Should I check n clean the filter first before I call for service? BTW, it's already out of warranty. I'm so distressed b/c I spent $2,000 last summer fixing a/c unit now this happens...I would appreciate any helpful comments.
    16 x 40 Geometric Inground Gunite w/ Spa (7' Diameter), Pebble Tec finish (Tahoe blue), 19K gallon, Baja Bench, Intellibrite LED lights, Masonly wall water feature w/ Travertin tile, Travertine coping and deck, Sta-Rite Modular Media 600 Cartridge filter, Max-E-Pro 2HP Pump & 1.5HP booster pump, Max-E-Therm 400K BTU heater, A&A Q-Max Dual Infloor Cleaning System
    Phoenix, Arizona
    38,262
    Re: Booster pump died in less than 3 yrs? I need some helps
    Certainly clean and inspect it. What kind of noises? Could be as simple as a capacitor.
