I gathered a lot of data this weekend. The full data is below, but my conclusion was that the DE filter was overloaded and clogged. Thinking back, I probably was putting in too much DE on re-fill, and not correcting for the DE left in the filter after backwash. I was able to hit 85GPM in all modes I tested (empty filter, filters only, filters + DE). With the suction crawler installed, I was able to get 40 GPM at 2070 RPM, 616 W, and 3 PSI. 60 GPM was unattainable with the suction crawler.
The issue now is the solar. With the system running at 32GPM, (1790 RPM, 420 W, 2 PSI) turning on the solar jumped RPM to 2340, Power to 750W and PSI to 10. Is that a reasonable jump for a solar system? The specs I can find for FAFCO solar panels list an expected head loss of 0.87psi for a single panel. I have 8 panels in parallel. I would think that would still leave me at around 1 PSI of head loss for the panels. However, I saw a jump of 8 PSI. Is that normal? Should I be examining those panels to see if they're working properly? I also ran the system at 40GPM with and without Solar, and got a jump of almost 13 PSI when I turned on the solar, so the problem does get worse with more flow. I tried to let the solar system stabilize to ensure that the flow was not being calculated during the initial water lift. The system was flowing smoothly with no large bubbles at the pool jets, and warm water flowing from them.
I appreciate all of the advice I've gotten so far, and I hope that you guys will continue to have sage guidance for me.
Data:
Empty Filter (No Filters or DE), No Suction Crawler, Solar Bypassed
Flow/RPM/Power/PSI
85/3230/2300/13.5
65/2485/1090/8
45/1860/500/4
40/1760/430/3.5
32/1435/265/2
Filter Medium installed, No DE, No Suction Crawler, Solar Bypassed
85/3290/2430/14
65/2550/1160/8
45/1920/538/3.5
40/1800/450/3
32/1445/268/1
Filter Medium and DE installed, No Suction Crawler, Solar Bypassed
85/3320/2478/14.5
65/2570/1183/8.5
45/1930/545/3.5
40/1810/457/3
Filter Medium and DE installed, Suction Crawler Installed, Solar Bypassed
60 Not Possible to attain. Reached Max power (3450RPM).
40/2070/616/3
32/1790/420/2
Filter Medium and DE installed, Suction Crawler Installed, Solar Active
40/2875/1295/16
32/2340/750/10
