Thread: Fafco solar panel leak advice
    I appear to have sprung a leak in a Fafco panel where the tubes meet the header. Normally there are pinhole leaks in the tubes but this appears to be at the point where the tubes connect to the header. I have searched the forums and the google but cannot find this exact fact pattern. Does anyone have experience/advice?
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Re: Fafco solar panel leak advice
    Try The HELICOL repair kits. They are made to repair the leak at that point.
    Tom & Yvonne
    Henderson Nevada
    17k in-ground
