Results 1 to 7 of 7
Thread: Hello from overseas
    Mar 2014
    Germany
    10
    Hello from overseas
    Hi all,
    my name is Marcus, 43 years old, from western germany. 4 years ago I started with a 4,57 diameter quick-up pool, last year I changed to a 7000 gallons inground steel-wall pool with sand-filter (50 kg. crushed glas filtration media, grade 1, 0,5-1,0 mm particles), salt-water, no chlorine-generator, chlorine is added manually.
    By chance I found this forum and found out, pools are running different in america than in germany. Unfortunately I've no photo of the entire pool, will be coming soon . The pool is still in winter dormancy, until this weekend, then it will awake.
    Here two photos of the skimmer in sand-filter:
    Nice to be with you, so long
    Marcus
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Hello from overseas
    Welcome to the forum
    We're glad you found your way over here
    You're done SLAMing when:
    38,262
    Welcome to TFP!!!
    Mar 2014
    Germany
    10
    Thanks for your warm welcome
    Ciao
    Marcus
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Hallo Marcus! Welcome to TFP, looking forward to your pics.
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome Marcus! Good to have you.
    Essential Links:
