Thread: Which Sand Pump/Filter System is best?
    stephlap4's Avatar
    Jun 2013
    Louisiana
    29
    I recently purchased a 15'x52" Verona Lomart above ground pool and need to purchase a pump/filter system. I am going with a sand filter system but not sure which is better:
    1) Oceania-C740010-Above-Ground-Pool-Filter-and-Pump-System
    OR
    2) Game-4511-SandPRO-75-Above-Ground-Sand-Pool-Filter
    OR
    3) AquaQuik SandPRO 20ES Sand Filter Pump System for Intex n Sun Above Ground Pools
    Any suggestions? I would really appreciate any input!!! THANKS!!!!
    Above Ground, Lomart Verona, 15'x52", 5800 gallons, TF-100 Test Kit
    38,235
    Re: Which Sand Pump/Filter System is best?
    Not sure there is such a thing as "best" since there is really nothing to a sand filter. Although generally the combo units may not be the best route to go as they typically have a pump that is too big and/or a filter that is too small. If you want a combo, pick the one with the smallest pump and the largest sand filter.
    I would suggest looking for a 14" sand filter and a 3/4 HP pump ... ideally a 2-speed pump.
