Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Wiring check
    Apr 2013
    Fayetteville, GA
    83
    Wiring check
    New pad poured, plumbing replace/re-route, new filter and filter pump motor....old timer.
    Just wanted to learn how this is/was wired for future reference and to ck that it was performed properly 15 years ago.
    18 x 36' Liner ~26,000g, 1 Skimmer (Supply)- 2 & 1 1/2" pipe, 3 Returns (jets), HEAD- ?, FILTER- Hayward 12002, 230v, SWG- AUTOPILOT DIG-220, PUMP- Challenger 346204 w/ USA MOTOR (rebuilt) SF 1.25/,02, CLEANER- Polaris 280- AO Smith 3/4hp., FEATURE- Hayward 1.5 HP Super Pump.
    Jun 2012
    western NY
    1,559
    Re: Wiring check
    What size breaker feeds that box from the main panel? I am a bit curious about the abandoned cable in the lower right hand side. That looks like it may have been the original feed based on the wire size. The wire feeding it now looks to be a bit small.
    Not real sure what the smaller white wires are doing on the terminals of the left hand timer. Kind of hard to trace them. It may be they are the power feeds to the timer motors.
    I am a bit concerned about what type of wire was used coming in and out of the box. My concern comes from the fact that two white wires were repurposed as hot leads. The way they are used is to code as they are marked. I am more concerned that they most likely come from romex type cable. If this is the case it must be rated for direct burial (uf-b)even if it is in pipe as NM is not rated for wet locations.
    What do the wires go to that hang out of the front of the box?
    As far as everything else, It looks pretty good. A little sloppier than I would like, but still functional.
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    Quote Originally Posted by danpik View Post
    I will have to check when I get home tomorrow.
    I did this temporarily just to work on the system and ID the wires and clean it up. It is a freeze guard.
    not sure here... prob is not up to code...I know the white wires are in conduit.
    What do the wires go to that hang out of the front of the box?...To a water feature
    This is a work in progress....and it is now a DIY because of this..."A little sloppier than I would like"....me to.
    Pretty sick/tired of all the crappy work that I have paid for over the years.
    Thanks for the help.
    38,271
    Re: Wiring check
    Your drawing looks fine. But in the picture I see a pair of red and black wires that are not in the drawing that are hooked to the timer on the left. Looks like the Red is always powered from one leg and the Black is powered from the other leg when the switch is on.
    Ideally you would have the pump supplied by a GFCI breaker, but with those added wires going to different loads (?) that could cause an imbalance and trigger a GFCI.
    Is there a GFCI somewhere on the light circuit at least???? I have my light circuit feed a GFCI outlet and then off the protected side of the outlet to my light ... maybe yours is the same?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Wiring check
    I don't think your drawing is correct although I suspect, in wire, it is correct.
    The hot feed wires, black and red in the drawing actually go up to the dual 20A circuit breaker at the left. The black wire feeds 1/2 of the circuit breaker, the red feeds the other half. This is done by the way the bus bars that are hidden behind the box's black plastic are configured.
    Same thing on the right side of your drawing. The black and red feeds are alternately delivering power to every other circuit breaker even thought they appear lined up with just the left side breakers or just the right side breakers.
    Here's sort of a map as to which color feed wire is actually feeding which circuit breaker.
    (Main Pump 20A) B----------B (Poollight ??A)
    (Main Pump 20A) R----------R (Cleaner Pump 20A)
    --------------------------------B (Cleaner Pump 20A)
    Bottom Feed Input) R-------B
    Had to use dashes instead of multiple spaces because the forum seems to convert multiple spaces into a single space and nothing lines up.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    38,271
    Re: Wiring check
    Good catch. The bus bars are not correct in the drawing ... everything after the breakers looks fine though.
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    Im still not home to ck this stuff but-
    There is a GFI on the light-
    those two B/R wire power the Autopilot SWG.
    Are you saying I need a 240v GFI at the Box for the Pump(s)?
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    THX ...I'm no electrician...
    I just drew what I saw and assumed...
    Making the drawing helped my mind wrap around the PFM of the wiring.
    Thinking I should replace the old GFI (15 years old) with a new one...?
    BTW Steve is the last guy to work on the system so I used the term "Steve Power" on the tags.
    38,271
    Re: Wiring check
    I think the new codes require a GFCI breaker on the pumps. That SWG wiring seems odd to me that one leg is always hot and the other is switched.
    Re: Wiring check
    A GFCI on the pump is required on nearly all new construction these days. In most areas it is not required on existing pools, but still a good idea. This is separate from the GFCI on the pool light, which is required period.
    Where I live it is illegal for any pool technician to touch a pool that doesn't have GFCI breakers on everything electrical within 15 feet of the pool. So you can have a non-GFCI pump, but you can't have it serviced.
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    So are you referring to a 240v GFI for the main pumps?
    Yes the SWG wiring is probably odd! It was kinda traumatic....I could not watch... The pool company that I paid a set price for the complete install hired a handyman type with no experience to do the SWG work...wiring/plumbing and it was supervised by the store secretary!!! + those R/B wires look to be HUGE...10ga.?
    OK - so I will probable be calling Autopilot for consult or maybe someone could direct me on how to properly perform the SWG electric hookup.
    beautiful work.... + I just found the Autopilot case ground/bond terminal was never connected...
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    Quote Originally Posted by JasonLion View Post
    Where I live I'm beginning to doubt qualified pool technicians exist!
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    did some research from Autopilot Model DIG-220 manual-
    I think it should be wired like this-
    input?
    38,271
    Re: Wiring check
    That is what I would have thought. Then the timer will turn on/off both legs of power to the SWG.
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    More decisions....
    I have a new 2 speed pump with a computerized control head with a built in timer.
    - a 280 Polaris cleaner with motor.
    - An Autopilot DIG 220.
    - Intermatic R30404R Timer.
    I just spoke with the folks at Autopilot and was informed that I can control the 2 speed motor and the SWG activation with the main Autopilot control head. All I need to do is add a relay. When the 2 speed motor is on low apparently the SWG should not be activated.
    What is the best way to control the 2 pumps (filter/cleaner) and the SWG system.
    1. could replace the Intermatic with a fully digital timer.
    2. Control the cleaner (Polaris) pump with the old mechanical Intermatic and run the filter pump off its own control head. Would have to run wires to the SWG system.
    3. Run the SWG and filter pump thru the Autopilot controller .......Polaris????
    2 spd-
    Re: Wiring check
    The AutoPilot is often fine at low speed. It depends on the details of your plumbing, but more often than not it works just fine at low speed.
    Using the AutoPilot to control high/low speed might not even be possible with that pump controller, and even if it is possible, it isn't very much use. Generally you want the pump on low speed all of the time and only switch it to high speed when vacuuming or backwashing.
    38,271
    Re: Wiring check
    Not sure I will be able to help here since I do not know how these systems work.
    I will say that the SWG should run fine with the pump on low. Mine does.
    I have never seen a 2-speed motor with a digital timer ... this may actually cause you problems in that it may not allow you to wire the low and high speed separately to be controlled by the SWG or another timer. And if you are going to allow some other timer to control it, why have an electronic timer on the motor in the first place?
    Apr 2013
    Fayetteville, GA
    83
    Re: Wiring check
    The Autopilot guy says it needs 15 GPM minimum flow...any idea what low is???
    I think the dig. controller can be pretty easily bypassed... Well I bought it this way and think I got a pretty good deal but was it necessary looks like maybe not...
    I think the Autopilot will work to control the pump at both speeds and possibly freeze guard protection....they seem to provide good fone support.
    Using the AutoPilot to control high/low speed might not even be possible with that pump controller, and even if it is possible, ...so how do you suggest I run the system?
    ...it isn't very much use.
    Generally you want the pump on low speed all of the time and only switch it to high speed when vacuuming or backwashing....wow did not know this. I assumed one would run it on high for at least a few hours a day in the heat of summer...
    I appreciate all the input
    38,271
    Re: Wiring check
    No idea what your flow rate will be on low speed ... too many factors that I do not know. Just try it and see if the SWG complains. Likely it will be well over 15 GPM.
  20. Back To Top    #20
    Re: Wiring check
    There are two approaches to wiring everything up that are similar: Use your existing external timer as the master timer, or use the AutoPilot as the master timer. Using the AutoPilot requires that you have the optional (but free) pump control relay, and gives you both freeze protection and failure to prime protection. Using your existing timer has the advantage of being less work to wire up and not requiring the AutoPilot relay.
    For high speed/low speed control I would just use the manual switches already on the pump, with it programmed to default to low speed and use high speed as a manual over-ride when you need it.
    As mentioned previously, it is very likely you have a good bit more than 15 GPM on low speed, but the only way to be sure is to try it.
