Thread: IC20 vs. IC40 physical dimensions
    May 2011
    Jax, FL
    3
    I have been searching and searching for the actual dimensions of these 2 units and cannot find them. I have an IC20 now on a ~23k pool/spa and the unit is getting old and will probably need replacement by the end of this year, maybe before. It should have been an IC40 from the get go so I'm wondering if the units are the same length or different? I'm thinking they are the same but don't know for sure. I appreciate all the help this forum has given me in the past.
    Re: IC20 vs. IC40 physical dimensions
    Welcome to TFP!
    They are interchangeable.
    May 2011
    Jax, FL
    3
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
    Thanks Jason for quick response to a fellow Marylander!
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I just bought a replacement ic40. They are the same. Do you know where you are buying it from?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    May 2011
    Jax, FL
    3
    Quote Originally Posted by Modawg2k View Post
    Don't have a place nailed down yet but most likely will be the cheapest place I can find when the time comes. Definitely open to suggestions
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I checked multiple local dealers and they were all 750 to 1000. You can find it for about 500 on amazon. I went with poolnpatio.net. it was about 530, called their customer service first and felt confident going with them. Their brick n mortar store in CA is dealer of pentair if that even matters
