Thread: Help identify this setup?
    Mar 2014
    Jackson, NJ
    2
    I'm in the process of buying a home. I took a quick photo of the pump area for the inground pool. I figured I could look it over when I got home. However this setup is very different then mine.
    I'm not sure what the small black dome is. It looks like the pump was removed for winter. I don't see a chlorinator. Any idea what that rectangle tower is in the background? Looks to large to be a light? The pool is still covered so I'm not sure how many jets and skimmers. I'm assuming two?
    Thanks!
    22,553
    Re: Help identify this setup?
    Welcome to TFP.
    The little dome is a distributor for an infloor cleaning system.
    If you can get a better picture of the "tower", we can probably identify it.
    Be thankful that you don't see a tablet feeder.
    I don't see a swg either, but I can't see all the plumbing.
    JoshU's Avatar
    New Orleans, LA
    543
    Does the pool have any sort of fiber optic lighting? It is hard to tell from the photo however it appears it could be a driver for a fiber optic lighting system.
    The filter is a sand filter however I don't recognize the brand/model from looking at the photo. Maybe if you post a photo of the valve top we can help better. It is always good to know what you have in advance in case you need parts in the future. I'm taking a guess that it might be a Jacuzzi brand filter based on what I can see.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Mar 2014
    Jackson, NJ
    2
    I'm not sure if it has lighting. I just looked up inflooring cleaning. That's crazy! I didn't see a pool heater. Zooming into the photo ..you are correct its a Jacuzzi brand filter. Not sure if that's good or bad. These parts of NJ are Hayward land or use to be.
    JoshU's Avatar
    New Orleans, LA
    543
    It's not a bad thing other than that parts can sometimes be hard to come by. Jacuzzi's pool business has changed hands several times over the years. A Canadian manufacturer has started making parts for a lot of the Jacuzzi pool products.
    It is a plastic tank which I prefer not to use on in-ground pools as fiberglass holds up better but if it is working now it is not a big deal. A different brand (comparable size) sand filter wouldn't really filter much differently.
    Could it just be a pedestal/bollard style garden light? Kind of looks like a commercial grade pathway light.
    38,532
    As others said, that dome looks like the manifold for in-floor pop-up jets ... BUT, I have never seen one where the pipes coming out are above ground with valves attached.
    What do all those stickers say?
