Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: I dont know which Hayward D.E. filter and pump to purchase for my above ground pool
    Mar 2014
    Texas
    10
    Question I dont know which Hayward D.E. filter and pump to purchase for my above ground pool
    I am looking in getting a d.e. filter system for my above ground pool. I was looking at the hayward d.e. preflex filtering system. I have a 36 ft diameter x 4.5 feet deep round pool (which is the water capacity of 34,300. Which model would be best for my pool I was thinking of the Hayward EC50C93S Perflex 1-1/2-Horsepower Extended-Cycle D.E. Filter Pool System. Please advise
    Jun 2013
    Erie pa
    68
    Re: I dont know which Hayward D.E. filter and pump to purchase for my above ground p
    I previously had the same filter on an agp and it worked fine, you should be able to get by with a 1 hp motor...same filter
    16x32 vinyl ig with foxguard steel walls,gli liner ,hayward de filter,hayward heatpro heat pump,hayward colorlogic 4.0 led.pentair circular weir skimmers.hayward sharkvac xl robot,gli mesh cover.polk atrium speakers,sonos music system.erie pa.
    Mar 2014
    Texas
    10
    i am just wondering what model to get for my size of pool.
    Mar 2014
    Texas
    10
    I would like to purchase this product very soon since it is still off season type prices. any help from the forum is gladly accepted..
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is a little small for that size pool. Normally, I would recommend at least 50 sqft for a 34k pool. Otherwise, you will be cleaning the filter fairly frequently. Also, the pump is a little large for that size filter. Both Pentair and Hayward seem to have better pairings (pump & filter) with Cartridge and Sand combo units. Are you set on a DE filter?
    Mark
    38,267
    I like my 60sqft DE filter on my 18k pool ... no way I would go smaller for a pool nearly double in size.
    Mar 2014
    Texas
    10
    all.... I would prefer a D.E. system.. So, which model size would best suit my pool... i will probably go with 1.5 pump... but what filter model is best me... hayward then goes to the EC65 and EC75... the pumps on both are the super pump III ... that is why I thought the EC50 would fit my needs... Help.... please....
    38,267
    You are usually better off buying the pump and filter separately instead of in a combo unit. The combos generally have pumps that are too big and filters that are too small.
    The EC50 is only 25 sqft of filtration ... Mark said to go at least 50 sqft and I think you would better with 60+ sqft.
    Even the EC75 is only 40 sqft.
    There is no reason to not consider an in-ground DE filter as it will likely better suit your very large AG pool ... which is in fact larger than most in ground pools. Hayward sells a 48 sqft, 60 sqft and 72 sqft DE filter in the Pro Grid line which I think would suit you better.
    Going with separate pump and filter would also allow you to look at the 2-speed 1HP pumps which are fine for your pool ... like the Haywar Power-flo.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by lauro63 View Post
    Where did you see that? I believe the pump that comes with the Hayward DE filters is the PowerFlo Matrix.
    I agree with Jason, to get the right size filter and pump, you will probably need to purchase them separately.
    Mark
    Mar 2014
    Texas
    10
    All, Thanks. My other question is.. can I purchase an in ground pool filtering system ... and make it work for my above ground? I thought it had to be strictly and above ground? Do I need to convert anything because i am going in-ground to above ground. Please let me know. Thanks
    38,267
    There is no real difference between in ground and above ground filters except for the sizes available.
    Pumps are a different story. Generally, you can use an IG pump on an AG pool, but not a AG pump on an IG pool.
    Mar 2014
    Texas
    10
    based on filtration area... I thought my pool was 34,000. so, is it 34 sq. ft. I guess I am confused in the calculation... please advise
    38,267
    We have advised we told you to look at 50 or 60 sqft at a minimum.
    It is not a calculation. It is based on general maximum flow rates through the filter and experience.
    There is a table we look at in the Hydraulics 101 sticky that is close (although we generally double the cartridge and DE numbers to be conservative). Going by that formula, would say you need a DE filter that is 93 sqft, but that is much bigger than really needed.
    Mark has another table he looks at that takes available sizes and flow rate requirements into account. (I should probably update my suggestions to match that).
    You are free to use whatever size you want, but bigger is generally better. I would not go smaller than the 60sqft on my pool which is a much smaller pool than yours. Smaller filter + bigger pool will just require more frequent cleaning hassle.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have an EC75 on my pool and like it a lot, only have to do a full cleaning on it 2 or 3 times per year depending on level of pool use, breaking it down and doing a full flush out acid bath once every 2 years, of course my pool is indoors so gets less debris, and have very low CH fill water.
    Ike
    Mar 2014
    Texas
    10
    So would the Hayward program model 4820, the one I should purchase?
    I meant progrid model 4820.
    mas985's Avatar
    Pleasanton, CA
    11,737
    What size and type of filter did you have previously and how often did you clean it?
    Sizing a filter, besides the pump, is also based upon your local conditions and how much debris (and type) gets into the pool.
    Mark
    Mar 2014
    Texas
    10
    Okay, If I purchase an In Ground filtering system (Hayward DE 4820) and I want to get a pump for my filter.. (which is the 1 hp 2speed) Do I get an In Ground Pump or and Above Ground Pump? Remember I have an Above Ground pool.
    mas985's Avatar
    Pleasanton, CA
    11,737
    You can get either but what about this:
    Mark
    38,267
    If you are only going with the 48 pro grid, I wonder if the ec75 would be better due to the ability to bump and not backwash every time. Personally I think at least the 60sqft would be better, although you need to answer Mark's question to be sure.
  20. Back To Top    #20
    Mar 2014
    Texas
    10
    instead of the hayward model 4820, I should go with the 6020? we currently have a cartridge filter, hayward swimpro voyager. we always clean it 4 times a year. the worst time is now. last spring and summer we had it turning green quite often.
