Thread: Any Fine Tuning?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Any Fine Tuning?
    Hey everyone, after owning a pool for 4 years, I'm going into my first swim season actually knowing what is in my water. Over the past month I've been working at lowering my TA thru dropping pH and aerating w/ my water feature. I replaced an inoperable Intellichlor w/ a new one this past week so I'm fine tuning the output on that right now so my FC is currently a little on the high side as I make daily adjustments to get the right level).
    Here are my numbers this morning. The only fine turning I was thinking about doing was getting the TA down to 60 to help slow my pH rise that is always constant. Any other thoughts? Thanks
    FC 7
    pH: 7.6
    TA: 70
    CYA: 70
    CH: ~450 (AZ hard water, nothing I can really do about it but I watch my CSI which is @ -0.24)
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Any Fine Tuning?
    Quote Originally Posted by Modawg2k View Post
    FC 7
    pH: 7.6
    TA: 70
    CYA: 70
    I wouldn't bother with the TA adjustment. When pH gets to 7.8, knock it back down to 7.2. That will also lower the TA. No point creating extra work for youirself.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree, focus on pH, not TA.
    Essential Links:
