Results 1 to 10 of 10
Thread: PH & Alkalinity
    Sep 2013
    DFW Metroplex
    119
    PH & Alkalinity
    Hello All,
    I have been playing cat and mouse game for almost 6 weeks, my alkalinity dropped to 60, so I keep adding baking soda to bring alkalinity to 90, this process raises the PH to above 8, by the time I reduce the PH to 7.4 with muriatic acid alkalinity drops back. I really appreciate an recommendation on how to tackle this problem.
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,590
    Re: PH & Alkalinity
    According to Pool Math, you should only need 85 ounces of baking soda to raise your TA by 30 and this should only raise your PH by .06 which is negligible. How much are you adding and how are you testing?
    Sounds like your PH is borderline high before adding the baking soda.
    Conversely, it should only take 20 ounces of muriatic acid to lower your PH from 8 to 7.4, which lowers your TA by 6. Close enough for hand grenades and horseshoes on TA level.
    Re: PH & Alkalinity
    Quote Originally Posted by missourian View Post
    I'm wondering about your word choice. Lowering PH should only take half an hour to an hour.
    It would be a big help if you could post a full set of test results. Also, do you have a waterfall, spa, fountain, negative edge, etc that is getting used during this period? And finally, do you have a SWG?
    Apr 2010
    East Texas
    9,590
    Re: PH & Alkalinity
    "Also, do you have a waterfall, spa, fountain, negative edge, etc that is getting used during this period? And finally, do you have a SWG? "--Jason
    ALL of those will raise PH btw.
    Sep 2013
    DFW Metroplex
    119
    Re: PH & Alkalinity
    Thanks, I added 5 lbs of baking soda last time and I was adding muriatic acid two to three times a week to keep the Ph around 7.5, this morning when I tested the alkalinity it went back to 60, I use TF 100 for all my testing.
    Re: PH & Alkalinity
    Try not adding nearly as much baking soda at one time as you have been doing, and also don't lower the PH quite as much.
    PH tends to drift up. The higher your TA, and the lower your PH, the faster PH will go up. Adding acid lowers both PH and TA, though it lowers PH way more quickly than TA. So if you are adding acid regularly, the TA will go down.
    In many cases it is possible to get the PH to settle around 7.7 when TA is around 60. If not, adding borates often help stabilize things, and also allows you to lower TA a little further, further slowing PH increases.
    Sep 2013
    DFW Metroplex
    119
    Re: PH & Alkalinity
    Quote Originally Posted by JasonLion View Post
    Quote Originally Posted by woodyp View Post
    Yes, I have waterfall and spa and I keep it running for 12 hours daily, No I don't have SWG, My complete test results;
    PH 7.5
    FC 4.5
    CC 0.5
    Alk 60
    Cal Hard 300
    CYA 50
    I have been following BBB since last august (I am not using Borax), Apart from daily bleach routine, weekly twice or thrice I add muriatic acid to bring the PH down as it always drift up to close to 8.
    Thanks Jason, I will follow this recommendation, I originally planned to add Borax into the mix by this summer may be I shouldn't wait.
    Apr 2010
    East Texas
    9,590
    Re: PH & Alkalinity
    You should add those items into your profile/signature line.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: PH & Alkalinity
    Maybe 60 TA is the sweet spot for your pool? If you don't raise it, how long can you go before pH rises to where you need to add acid again? Remember, those target values are guidelines; they aren't absolute; least of all the TA level. Without knowing the water temperature, it's impossible to say what the CSI is for certain, but at a reasonable guess of 65F, you're still essentially neutral, slightly negative in fact, which is okay with your vinyl liner since it won't etch like a plaster surface.
    Try not adding any baking soda and keep an eye on pH. Maybe your pool will just sit there all year with a steady pH if you just leave TA where it is. That's my suggestion.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PH & Alkalinity
    Again I agree. Don't focus on TA, but pH instead. It is vastly more important, almost always.
    Essential Links:
