Results 1 to 9 of 9
Thread: Double check before I get started.
    Apr 2013
    Tallahassee Fl
    30
    So started getting ready for the season,
    I had a massive algea bloom almost no CYA so started by cleaning it out and shocking Pool info
    25k vinyl inground pool sand filter
    Just installed a Circupool SI-30
    After three days Cl is holding steady.
    FC is at 5
    no combined chlorine
    Calcium hardness is 130
    TA 130
    PH is 8.0+
    Acid demand test was 9 drops so according to taylors chart I need to add about 1.5Gallons Acid. I added a gallon for now
    Going to get some CYA today at HD to add to pool.
    With regard to the salt system since I am a newb.
    When turned off the system reports 3200ppm salt when it runs for an hour is says low salt yet the manual says keep the Nacl between 32-3400ppm. thoughts?
    30+ YO, IG, 20Kgal, Vinyl(2YO), Circupool SI30 sand flterr, hayword sp2302 VSP, (3/4hp pump for polaris(never use)
    38,235
    Re: Double check before I get started.
    Did you follow the SLAM process until you passed the 3 criteria to stop?
    If the SWG says low salt, then you need to add some ... got to make it happy. Do you have an independent salt test?
    You certainly need to get the CYA up or the SWG will not be able to keep reasonable FC levels.
    Good idea doing the pH in 2 steps.
    Apr 2013
    Tallahassee Fl
    30
    Just added 60lbs of salt to bring me up to 3500 ppm.
    6lbs of CYA I think based on my personal test I am at about 10ppm so that should bring me to 40ppm. adding this much CYA will drop the PH a bit too?
    So my plan is to check the FCL daily and retest the CYA and PH in a week and make any adjustment needed then... sound like a good plan?
    Smykowski's Avatar
    Sep 2011
    3,065
    How does the water look?
    Also, you didn't answer this question:
    Apr 2013
    Tallahassee Fl
    30
    Slam- Yes,
    Water is Def clearing out went from swamp green to ocean green, however the massive amounts of pollen falling have the pool looking a bit yellow. i'm sure the 2.5" of rain we are supposed to get tonight will have some affect, i knew it was coming so i let the water get low. Pump is/has been running 24/7.
    Smykowski's Avatar
    Sep 2011
    3,065
    Rain will have very little effect on the pool.
    Are you saying that the water was at one point crystal clear this spring, but now is clouding up again?
    Apr 2013
    Tallahassee Fl
    30
    Sorry for the lack of updates got busy with school. I boght more chlorine to shock the pool and got busy so my wife decided to add it herself with the pump chlorinator running 24/7. I finally got a Chance to vacuum the pool and check the water today now that semester is almost over and I have a new problem.
    FC is 30, I will keep checking this every other day till I get closet to my target. then
    TA110
    CYA 80-90
    Didnt bother testing PH as I know super high CL will throw off PH reading.
    Should I dilute the pool to bring down the FC or let it ride. I have turned off the Salt water chlorinator and set the pump to run 8 hrs a day based on last years required filtering to keep the pool clean and clear. will turn it back on when FC drops. We have 80F and sunny in the forcast for next week.
    You say rain will have very little effect but when it rains for 24-36 hrs strait at an average 0.5-1" and hour it has to do something.
    Quote Originally Posted by Smykowski View Post
    Nope We let it take a natural course over the winter so this spring started with swamp green water and 100lbs + or - of organic matter and a dead squirrel.
    It is now crystal clear
    30,400
    Well, of course, if you got 20" of rain in Tallahassee it will have an effect but it is safe to say that MOST OF THE TIME, rain has little effect on a pool's chemistry.
    How much rain did you get??
    Apr 2013
    Tallahassee Fl
    30
    bout that much the last couple days......I decided to just let it ride, light bill went up a solid $100 by letting the pump run 24/7.
