Thread: Hayward Goldline AQ-TROL-RJ
    rippermac's Avatar
    Aug 2013
    Virginia Beach
    15
    Hi all experts. I've been lurking and learning since last summer and it's time to get involved.
    The time is coming to open or prep for summer action and I need advice/info. I have a above ground 15x30 oval ~12k
    with a bs swg that the pool guy said would work great (never really did) and all summer long I added chems cause it couldn't keep up
    with basic demand. I'm done with it and plan on moving to a more robust generator. I have in mind the Hayward Goldline AQ-TROL-RJ
    and would love to have some opinions on it before I make the purchase and install. Also, would using a swg not specific for above grounds be
    an issue? I plan on purchasing over the internet so links to reputable dealers would be also appreciated. Thanks for any and all info.
    Regards
    38,251
    Re: Hayward Goldline AQ-TROL-RJ
    The Hayward SWG work well. The one you mentioned is for an above ground pool right? Where the cell is installed by the return jet so a flow switch is not used.
    But, you should be able to use any SWG you want, the install is the same, assuming you have hard PVC.
    Goldline, a Hayward brand, SWGs are very well though of. Using a SWG with an above ground pool is just fine. You just need to make sure to patch any leaks reasonably quickly (which you should be doing anyway).
    rippermac's Avatar
    Aug 2013
    Virginia Beach
    15
    That is what I was hoping to hear..thanks for the info..helped to solidify my decision. I'm pretty much a perfectionist so no leaks will be acceptable as a matter of course.
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Have had one for several years ..no issues here at all .. going to replace cell this year after 4 years of service..
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
    JoshU's Avatar
    New Orleans, LA
    542
    Yes, the AquaTrol is the above ground version of the AquaRite. It is slightly different in features. The RJ model hooks up to the return jet.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
