Results 1 to 7 of 7
Thread: Hose connections help
    Jun 2010
    Central Indiana
    92
    Looking for guidance connecting my pump to filter. I have a bunch if the white flexible PVC? Stuff seen in the included pic. From the skimmer to my pump is hard pipe with a screw on connection. My outlet on my pump has a barbed connector as seen in the background of this picture. My filter has a smooth (1 barb at end) connection similar to the one you can see in this picture in white. So do I just slide the white flexible PVC over the barbed pump fitting and hose clamp and over the smoother filter fitting and hose clamp?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Hose connections help
    Pic didn't post.
    Jun 2010
    Central Indiana
    92
    Sorry pic added
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    That's what it looks like to me. Try softening the ends of the flex in a pot of hot water before you try wrestling them on. And don't forget to slip the hose clamps on before you make the final attachment!
    Jun 2010
    Central Indiana
    92
    Well I went ahead and bought hose barb ends (like what's on the pump) to replace the smooth ends to put the flex pipe over. However, I'm still a bit confused. I've read other threads on here saying you can't use hose clamps with the white flex pvc hose but that's all that is here so it must be what the previous owners used. So do I need to get a different type of hose to to make the connections or is it ok to use flex pvc over hose barb end with hose clamps?
    The flex pvc pipe in the picture is not designed to be used with barbed fittings. It has internal ribs to resist collapse. It might work, but it's really not correct. Flex pvc pipe is designed to be glued into pvc fittings like regular rigid schedule 40 pvc pipe.
    There is hose and tubing designed for barbed fittings.
    You can do it either way, but you should use the fittings and pipe or tubing or hose in the proper combination.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by JamesW View Post
    This is what I was thinking. I've only used black flexible PVC, but it was meant to be glued, just like regular rigid stuff.
    Essential Links:
