Results 1 to 11 of 11
Thread: Dog pooped in pool, Any special precautions?
    Guest
    What a end to a perfect day. Had my daughters 10th birthday party and everything went great. Except... after the party, I let dogs out and one of them pooped on the baja step in the pool. I got most of it out with the leaf skimmer. Other than shocking the pool, any other precautions I should take? Not sure if this is the right place for this topic.
    Thanks
    Sal
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Dog pooped in pool, Any special precautions?
    Good thing it happened after the party. Can you just imagine those 10 year olds squealing if they had been in it? EUWW! GROSS!!! MO-O-MM!
    You did the right thing: remove what you can, then shock the water. It happened to us when our very old dog had an accident while swimming. I closed the pool for the day, shocked it, and let the chlorine drift back down. There were no ill effects, not on the pool nor on people.
    Poop happens
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Guest
    That's the first time and I hope the last time. He must have been real thirsty, cause he was drinking at the same time. He is my freak dog!
    Thanks for the info
    Sal
    Casey's Avatar
    SW PA
    10,450
    I'm glad my doggy get's out to pee! 8)
    Dec 2007
    Central New York
    504
    HIGH CHLORINE DOSAGE WORKSHEET
    Use only after contamination of pool by feces or vomitus.
    Complete the worksheet and keep it in your log book under the incident date.
    CAUTION:
    ♦ You are using this worksheet because your pool has been contaminated by feces or vomitus AND the responsible person is ill or suspected to be ill, OR the stool or vomitus is loose or spread into a large area.
    ♦ Use this sheet only if the pool cannot be closed for 24 hours (see Step 4b on the other side of this guide).
    ♦ Be aware that you will be trying to reach a high chlorine residual. After determining the needed chlorine level, you should contact your swimming pool equipment supplier to ensure this level will not have a harmful effect on the pool or equipment.
    ♦ Do not use this procedure unless you are familiar with calculating and reaching high chlorine residuals.
    ♦ Do not use this procedure unless you understand how to use your chlorine test kit to accurately read high chlorine residuals.
    ♦ Do not use this procedure unless you can quickly lower high free chlorine residuals to less than 6 PPM.
    Time and Concentration Calculation:
    Use this chart to determine the amount of time you wish to keep the pool closed and the minimum concentration of chlorine necessary for that time to ensure bacteria from the incident are killed. Times different from the chart can be calculated by using the formula: 7,200 ÷ T = C or 7,200 ÷ Time in minutes = the Concentration of chlorine in PPM.
    TIME ------------------ CHLORINE
    4 HOURS ................ 30PPM
    6 HOURS ................ 20PPM
    8 HOURS ................ 15PPM
    10 HOURS ............... 12PPM
    12 HOURS ................ 10PPM
    14 HOURS ................. 9PPM
    16 HOURS ................. 8PPM
    18 HOURS ................. 7PPM
    20 HOURS ................. 6PPM
    Amount of Chlorine Needed:
    The amount of chlorine needed to achieve the PPM you have determined will depend on: 1) the volume of water in your pool and, 2) the concentration of the chlorine you are using. Read the product information with the chlorine you are using, or contact your pool equipment supplier. You might consider using chlorine made for shocking which would dissipate quickly. The pool cannot be opened until the free chlorine level is below 6 PPM.
    Well, this is part of one worksheet for a public pool. I am not saying this is right or wrong. I'll just say it can be used as a guide.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Mar 2007
    San Rafael, CA USA
    12,082
    That worksheet is old and based on the older CT value for Cryptosporidium (a protozoan oocyst) of 7200. The latest CDC recommendations for a fecal response are shown here where a CT value of Crypto is now given as 15,300. The thing is that with CYA in the water it is not practical to get the chlorine level to the equivalent of 10 ppm FC with no CYA. You'd have to have an FC that is approximately 10 ppm higher than the CYA level in order to do that.
    It is unlikely that the dog had Crypto unless the dog had diarrhea and even then it is not likely. In this specific case, it sounds like a formed stool so Crypto is very unlikely.
    I would just shock the pool at normal shock levels as that will kill most pathogens (bacteria and viruses) in less than a minute and some heartier pathogens within minutes. At shock levels (an FC that is 40% of the CYA level) even Giardia (another protozoan oocyst) will be inactivated in a little over an hour.
    Richard
    Guest
    Awesome, Thanks for all the info. I did get most of it out and threw in a gallon of chlorine right after the incident. Just to be safe, no swimming today and I need one - two more gallons to shock my pool.
    Thanks Again!
    Dec 2007
    Central New York
    504
    So the new CT value is 15,300 for worse case, figuring Crypto.
    So 15300 divided by 100 PPM equals 153 minutes.
    If you close the pool for a day it's 24 X 60 = 1440.
    1440 divided into 15300 equals 10.6 PPM. So the gov't says you should shock with a 11 PPM with the pool closed for 24 hours.
    Hotrod30
    Pentair VF3050 pump
    Mar 2007
    San Rafael, CA USA
    12,082
    Generally speaking, I wouldn't worry about Crypto in a residential pool.
    As for your calculation, it doesn't apply when there is CYA in the water and I give some more info about this in this thread (it's too technical for the main forums).
    Richard
    Guest
    Regardless, with a CYA of 65ppm. I have to reach about 20ppm to get to the proper shocking level correct?
    Thanks
    sp
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, that 20 ppm FC would be fine. Just keep it at that level for at least a few hours and then let it drop on its own (it will drop during the day from sunlight).
