Thread: Travertine Backsplash Tile
    Jan 2014
    SE Louisiana
    147
    We're having trouble deciding what kind of material to use for our raised bond beam and spa. We want something to match our ivory travertine coping, but we're not all the happy with the waterline tiles that are made to imitate the look of the travertine. Has anyone ever seen basic 4x4 or 2x2 tumbled travertine tile that is typically used for kitchen backsplash, used for a raised bond beam or spa. This would not be used at the waterline, but it would certainly get wet often with splashing and the spa spillover.
    We are going to have glass tile at waterline. I'm thinking I would have to use the same method on the travertine. waterseal/membrane, mortar, thin set, travertine. Would this be significantly different from the tumbled travertine that is being used for coping? Any big risk with doing this?
    Thanks
    Scot
    CCisotope's Avatar
    Aug 2013
    Cypress, TX
    136
    Re: Travertine Backsplash Tile
    Scot,
    I found a couple waterline tiles that match well with the lighter ivory travertine coping. We used a smooth polish ceramic waterline tile that looks close to travertine, it was a 6x6. The one thing to consider since it is polished is that it will have a bit of a glare when the sunlight hits it. The item number for it is in my build thread if your interested.
    If you have an MSI or QDI stone showroom close to your location, they have a variety of travertine in the sizes you want that is used for kitchen backsplashes. You can also check out their website too, if you call them they can help with the application process.
    IG Gunite 30k gallons, custom WetEdge finish with glass beads, spa, Pentair 520sq. ft. Cartridge Filter, Pentair 3HP intelliflow V.S pump, Pentair 400K BTU Heater Master Temp, Pentair 2HP Whisperflo- Model WF-28, Silencer Air Blower 1.5 HP, Pentair Boost Rite Universal Booster Pump, Rainbow 320, Easy Touch 8, My pool build:http://www.troublefreepool.com/threa...ypress-TX-Pics
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    if you click on "my pool build" in my signature. you will see that we found tile that matches our travertine almost perfectly. I am not sure if our travertine is the same color as yours
    17k IG pool (34' X 19'), Pebble Plus Interior - Artic, Hayward ECO Star Variable Speed Pump, Hayward ProLogic P-4, Hayward 480 Cartridge Filter,
    (2) Jandy Deck Jet's and (1) bubbler, Wave Force Cleaning System, Trident UV sanitation System, TF-100 test kit with SpeedStir
    My Pool Build
    Jan 2014
    SE Louisiana
    147
    Thanks for the replies. I will check into these.
    Scot
