Thread: If something goes wrong!
    Mar 2007
    Coastalish 'down easter'
    4,160
    You'd think it'd be obvious, but sometimes it's not!
    If you ever go to your pump/ filter and hear a strange noise or see water squirting out of the plumbing --- turn off the pump!!!!!
    I had to replace the lines between the pump and filter today because the pool owners son didn't mention a strange noise when he checked the pump a couple of days ago, the noise was the pump starving for water.
    The reason for this post is to tell people to shut down the pump system if something is amiss, ask a question here or have the local pool dude check it out - before!! a major problem arises
    Luv& Luk
    -Ted
    Casey's Avatar
    SW PA
    10,450
    Re: If something goes wrong!
    For a second, I thought you were gonna say you got your fingers chewed off.
    Thank goodness you didn't but you're right! Turn off your pump and come here!
