Thread: Liquid chlorine V trichlor
    May 2013
    Cyprus
    159
    Hi Everybody
    I could do with some advice. I was at my chemical supplier today and purchased a drum of liquid chlorine 12%. He then advised me to use trichlor as the liquid chlorine would not be strong enough in the summer with temp around 35 C. Is trichlor better than liquid chlorine not withstanding the Cya problem
    Thanks
    Living in Cyprus
    Still enjoying life
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: Liquid chlorine V trichlor
    As long as you have enough CYA in there, (which you can add separately) chlorine is chlorine is chlorine. The benefit being you can keep close control on your CYA level.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    No, he is incorrect. Remind him that TRICHLOR adds cya, and it builds up in the pool. Liquid Chlorine does not, and it is more than strong enough.
    As WoodyP says, you can maintain tight control of Cya using Bleach. Then you can add CYA IF YOU NEED IT.
    Essential Links:
    Trichlor adds chlorine, adds CYA, and lowers the PH. Occasionally you need all three effects and using trichlor is handy. However, most of the time you only want one or two of those effects and the remaining ones cause problems.
    When you need all three effects, trichlor is "better" in some sense, the rest of the time it is "worse". In practice, it is unusual to need all three effects at the same time, and even if you do, it is simple enough to adjust each of the levels separately.
