Results 1 to 11 of 11
Thread: Bubbles coming out of return
    Jun 2013
    Southwest Louisiana
    72
    What would cause bursts of bubbles to come out of one of my returns? I have 3 returns but it only comes out of one.
    Installed in September, 2013 18x36 (28,000 gallons) lagoon shaped, vinyl pool, with steel walls. Pentair intelliflo variable speed pump, intellichlor salt generator, pentair cartridge filter CCP320
    Re: Bubbles coming out of return
    That means air is getting into the system. If you primed the pump today, it could simply be air that is getting flushed out of the system. But if the system was primed before today it usually means air continues to get in.
    The most common causes for air getting into the system include a low water level allowing a vortex to form in the skimmer that draws in air, the pump strainer basket lid not sealing correctly, or a suction side air leak.
    Jun 2013
    Southwest Louisiana
    72
    Thank you Jason, it has done this since the pool was installed last September. My pool builder told me it was gas caused by the swg. We have had a lot of problems and I'm trying to figure them all out and see how it's all connected. If I had a leak in a pipe somewhere could that cause air to get into the system? I'm loosing water in the pool. I've kept my water level pretty high since the pool leaks somewhere, I am afraid to keep it at normal levels with a constant leak so I always keep it filled above normal. We have cleaned the strainer basket quite regularly and even after putting the lid back on we still have the bubbles. So it looks like I'm looking at a suction side air leak then.
    SWG systems do produce bubbles, but they are normally far far smaller then the ones in your picture. The SWG theory, however unlikely, is easy to test. If the bubbles are coming from the SWG, there won't be any bubbles if the SWG is off. Bubbles when the SWG is off must be coming from somewhere else.
    A suction side air leak (while the pump is on) can also be a water leak when the pump is off, which fits your description fairly well.
    Jun 2013
    Southwest Louisiana
    72
    Thank you, I never thought to try turning the swg off. I'm going to do that today. My pump runs 24 hours a day, so could water still be leaking and air coming in?
    Kim
    No, a single leak would either let in air, or let water out, but not both at the same time.
    Jun 2013
    Southwest Louisiana
    72
    Thank you.
    Jun 2013
    Southwest Louisiana
    72
    I turned the swg off and still had bubbles. There was a very small amount of moisture around this pipe coming out of the pump. Could this be causing the air coming in?
    No, that vertical pipe is on the pressure side of the pump, not the suction side, so it can't let air in while the pump is running.
    30,419
    No. That is on the pressure side of your system and will not let air in........it would be leaking water very noticeably but not air. Suction leaks are sometimes very hard to find and if you are not a DIY person, I would suggest you call a pool service to locate it for you.
    Jun 2013
    Southwest Louisiana
    72
    My pool is still under warranty with my builder. I was just trying to figure something out on my own until he comes back. We have had nothing but problems since it was finished in September and just slowly trying to piece together all of the problems and see how they are connected. He said he will find it and fix it I'm just getting impatient so have been trying to figure it all out on my own. Thank you for the help.
    Kim
