Spa Draining Partially Nightly
Dec 22, 2013
1
My spa is getting drained every nite although I fill back up after the fact. Both of my check valves were replaced in an effort to correct the draining issue, with no effect. Also, in the last year I have also replaced two out of three actuater valves, both in the last 3 months. Although the issue started right around that time. Any suggestions? Pleading for help.
Thanks
Welcome to TFP!
It is possible that one of the actuators is not configured correctly and does not completely close one of the valves when the pump is off. Another possible cause is a leak, which could even be unrelated to the plumbing (though that is quite rare).
