Thread: What is this? A chlorinator?
    Mar 2014
    Fresno, Ca
    2
    I am a long time lurker and first time poster, I have learned just about everything from you guys! I have an in ground pool and spa that are connected by a waterfall. When the spa was turned on I found that it was emptying to the pool. I closed the valve on this thing and it solved the problem. It seems to still be leaking a bit and I was thinking about just plugging it up rather than trying to tighten the valve. Do you guys think that this is a good idea? Thanks!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What is this? A chlorinator?
    It might be a one way check valve, I can't really tell from that photo though
    22,553
    Looks like a check valve to me too. Does it have an arrow on it anywhere?
    Mar 2014
    Fresno, Ca
    2
    Quote Originally Posted by Bama Rambler View Post
    I don't see an arrow anywhere but I think you guys might be right.
    30,432
    If it's a check valve, you could probably do a neat looking fix by unscrewing both valves (assuming the are both threaded) and then connecting back straight across with pvc pipe
    Ozone filter?
    pool size - 40kgal
    finish - Gunite
    pump size in horsepower and brand-Variable Speed, Hayward EcoStar SVRS3400
    filter size - Sta-Rite S8M150
    additional equipment - Hayward CL220 Chlorinator
