Thread: RO service in Los Angeles?
    May 2011
    Los Angeles, CA
    228
    Hello everyone,
    Does anyone know of a RO service in Los Angeles particularly in West Hills/ Canoga Park area?
    My CH was near 600 when i closed the pool and the water was also tasting a bit salty so Im thinking of RO rather than a water change. Tap water was CH around 90 last year but i dont know what it will be when i open the pool.
    Any help would be appreciated.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    38,301
    Re: RO service in Los Angeles?
    Changing water is likely cheaper even if RO is available. I only know of a company in Escondido and San Diego.
    Of course with a little care, you can manage a pool with a CH of 600ppm ... some members have tap water over 700ppm.
    I also highly doubt your salt level is higher than what is required for a SWG pool, so that should not be a concern.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I normally replace my water this time of year because of high CH but this year I am probably going to skip it and just deal with the high CH since CA is dealing with a drought. My CH is over 600 ppm too and there have been years where I let it get close to 900 ppm before refilling so I know it can be managed that high. You just need to keep PH at the lower end of the range ~7.2 and you should be ok. Oh and stock up on acid, you will probably need it.
    Mark
