Thread: Test kits TF-100 or TF-50
    Jun 2010
    Central Indiana
    92
    I already have a basic OTO/PH test kit at home so I am trying to decide if I need the TF-100 or the TF-50? The only differences that I caught for sure is the TF-100 includes the basic test kit I already have as well as more solutions to complete more tests...but since these things expire over time do I really need that many extra? Is it worth the extra $23 for the TF-100?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    Re: Test kits TF-100 or TF-50
    That depends on how tight on money you are. Most people doing standard testing for an entire pool season will prefer the TF-100, though it is certainly possible to get by with the TF-50 (if you don't get algae too often). The TF-50 has half as much R-0871, which is one of the most common reagents to run out of when you have a TF-100.
    Also, the reagents should last two years (or more) if stored carefully, which is more than enough time to need to do lots of testing.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Personally I would only consider the TF-50 for smaller seasonal pools that start with fresh water every season.
    Ike
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I don't completely agree. If you have a pH/OTO Chlorine block and need to save the money, get the TF 50.
    Essential Links:
    30,432
    The TF-50 is set up for people like OP who already has a viable pH test (he does) and, As Jason Lion indicates, keeps a pretty clean pool.
    While the TF-100 is the correct choice for the vast majority of us, The TF-50 sounds like a good fit for OP.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea I agree on that.
    Essential Links:
