Results 1 to 14 of 14
Thread: Confused about FC test
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I merged the similar posts as well. jblizzle
    Moved post. Please start your own thread when you have a question Butterfly
    Post here since I'm still somewhat of a newbie. New test kit for me too. I'm confused about the FC TEST. I tested at 25 mm. I'm not sure what number I'm suppose to use to multiply by.
    FC ?
    CC 0
    pH 7.4
    TA 100
    Ch 160
    CYA 60. I know this is a tad high. Was using those bad ole tabs during the winter. It was 126 before replacing some water and slamming etc
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I'm still somewhat of a newbie. New test kit for me too. I'm confused about the FC TEST. I tested at 25 mm. I'm not sure what number I'm suppose to use to multiply by. It says 1 drop = 0.2. 1 drop = 0.5 which is confusing.
    FC ?
    CC 0
    pH 7.4
    TA 100
    Ch 160
    Montgomery, AL
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Confused about FC test
    With a 25 ml sample, multiply by 0.2.
    With a 10 ml sample, multiply by 0.5
    The 10 ml sample is accurate enough for day-to day use, and saves on reagent.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test results - confused on FC test
    Here's a quote from the Extended Test Kit Directions
    There isn't normally any reason to do this, but if you need more precision you can do this test with a 25 ml sample of pool water and multiply the number of drops by 0.2. In most situations the added precision is useless and simply wastes reagent.
    Here's a link http://www.troublefreepool.com/threa...Kit-Directions
    You're done SLAMing when:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I will go beyond what Richard said, and say the 10 ml .5 FC per drop is all you will ever need, there is no need to test to higher accuracy than this when dealing with a residential pool which is using CYA stabilizer as you could have variation close to this from one sample to another depending on what part of the pool they come from and how good your circulation is.
    Ike
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Good to know cause I've been going thru some reagents...gotta order more already Thanks loads
    Montgomery, AL
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    So, my FC is 14.8. After slamming, week and a half ago then sunny days it was 43 5 days ago, 19 yesterday and it rained all night last night.
    Montgomery, AL
    38,486
    A FC of 43ppm is way too high, how did you overshoot so far?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Before I got my test kit, 3 wks ago, water was green, took a sample to the local yokels....my cya was 126, TA 0 ch 60 ph 6.29 FC 1.0. They had me add 25 lb ALK, 25 lbs cal, 12 cups ph up, algicide 2000 then shock each night 6 cups chlorine each night for 5 nights. After brushing and vacuuming none stop, pool looks great but I think they really overshot everything. It is now BBB for me.
    Montgomery, AL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yikes! Good for you taking this on yourself. It will be the best thing you ever do for your pool. Do spend some time in Pool School. The ABC's is a good place to get started. Right now is a good time to replenish your kit, as TF Testkits has a reagent sale running.
    Essential Links:
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I've been reading pool school for over a year. I think I've also read every post in the forum. It's very overwhelming but some is starting to sink in. You all are all so **** smart! Trouble is most of it is over my head. I'm determined though!
    Montgomery, AL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Focus first on Chlorine and pH. These are the two most critical parameters that need frequent attention. Do you have a specific question about either?
    Essential Links:
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I think I'm good...chlorine level is based on cya level. I'll use the pool calculator since I'm anxious as to how much to add when it's time.
    Montgomery, AL
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Pool math will answer that. Just take your time entering the correct data and it will take care of you.
    Essential Links:
