Thread: Closing main drain valve when vacuuming
    Exclamation Closing main drain valve when vacuuming
    does anyone else do this? My pool has 3 skimmers. I put the vacuum hose in one of them, then I plug the other 2 skimmers with 2" pvc pipes that are capped and filled with water. Then I go close the main drain gate valve until the vacuum gauge hits 15 inches of pressure. Then I start vacuuming.
    -38,000 gallon pool and 1600 gallon spa
    -Triton II TR140 sand filter
    -In ground
    38,284
    Re: Closing main drain valve when vacuuming
    You have to do what you have to do in order to get enough suction through the vac. I would guess most people do not have so many hoops to jump through though ... likely just having to adjust one valve.
    You have 3 skimmers on a 2k gallon pool?
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    I turn the valve on my main drains to limit them and cause an increase of suction through my one skimmer to vacuum. It works well.
    ah the pool is 38k gallons and is a public pool. This is the only pool that I work on. Also, I work on a 1600 gallon spa. place is too cheap to buy me one of the robotic vacuums. I doubt they can vacuum in corners and steps anyways.
    -In ground
    38,284
    Oh, is the signature that is shown not yours? There were some hiccups when we switched forum software with signatures showing up when members did not originally have one.
    There we go, fixed it
    -In ground
