Results 1 to 7 of 7
Thread: LED Pool light not working a week or so after photocell installed
    Mar 2014
    Arizona
    8
    I have an Intellibright 5G LED pool light (http://www.pentairpool.com/products/...-lights-74.htm) that is less than a year old and I had my friend (licensed electrician) install a photocell (this one http://www.homedepot.com/p/Red-Dot-1...C652/204193195) and also a by-pass switch and everything was working fine, but then a week or so later it stopped.
    The photocell was acting sort of funny because it is on the side of my house, which has some shade, causing the pool light to turn on/off every few minutes at some points.
    I was going to have him switch everything back and then call the pool company (Shasta) and make them fix it, but I'm curious if I can just leave the photocell and still have them fix it. I searched all 4 manuals posted on the manufacturer's webpage and I haven't seen anything that says I can't install a photocell by a licensed electrician.
    Thoughts on what I should do or does anybody have any experience with these lights failing when used with a photocell?
    Re: LED Pool light not working a week or so after photocell installed
    Mine is wired to a photocell, then the lighting relay (Easytouch), then the 12 VAC transformer, then the two lamps.
    No issues
    Photocells in my experience can not take direct sunlight, they burn out. I would suspect your photocell first.
    Easytouch, Intelliflo, Intellichem, Acid tank with pump, Intellichlor and Autelis network interface.
    Mar 2014
    Arizona
    8
    Quote Originally Posted by jerryt View Post
    No issues
    It's a brand new photocell that doesn't receive direct sunlight and I have a bypass switch setup too. So I normally have the bypass switch turned off, and the photocell will provide power or not, but when I flip switch, it flows through either one.
    I don't see how a photo-cell could hurt the intellibrite, second most likely failure is a bad connection, wire pulled out of a wire nut...
    Need to check out the system with a voltmeter...
    Mar 2014
    Arizona
    8
    To bring this thread some closure...the light was bad. I think it went bad from having the photocell hooked up backwards. I don't quite see how it would damage it, but I think it did.
    The intellibrite 5g fixtures are not compatible with triac (electronic) switching, as I found out. If your photocell doesn't contain a relay, I wouldn't use it. If it said something like 'for use with incandescent lights only' in the photocell instructions this would be a hint that it isn't suitable for what you are trying to do.
    Jun 2014
    El Reno OK
    11
    Also FYI, 9/10 when a photocell fails it always stays on.
