Results 1 to 7 of 7
Thread: Pump won't run.
    Mar 2014
    Arizona
    3
    Pump won't run.
    Hello all, I'm having a bit of trouble with my pool pump and I'm not sure how to proceed.
    The pump is a Jandy PHPF1.5 and has a label that also says A.O.Smith Centurion.
    After skimming the surface this morning, I tried to vacuum the bottom of the pool and came upon a stuck manual switch. I removed the two metal set screws/trips that activate the pump at night. The switch was locked almost in the off position, but not quite. And the timer was stuck at 3am, when i have it set to run. After removing the trips, I pulled the dial forward and set the correct time and flipped the manual switch to on. Nothing happened, no noise at all.
    I checked the breaker for the house and flipped the pool pump breaker off and on again, back to the pool pump and the motor just hums and trips the breaker.
    I removed the access cover for the filter on the pump's wet side and cleaned it out. I also removed the small cover on the backside of the pump to see if the pumps rotor would turn and it does.
    Being that the pumps rotor spins freely(with a wrench easily, and by hand if you put some muscle to it), I'm at a loss as to what I need to check next.
    I can take pictures if need be. The rest of the equipment is a mix of Jandy and Hayward.
    22,553
    Re: Pump won't run.
    That sounds like the start capacitor or the centrifugal switch contacts. It's fairly common for the capacitor to go bad and it's easily replaced.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump won't run.
    http://www.youtube.com/watch?v=ZEIv5ClLqXg
    They say a picture is worth a thousand words.
    Mar 2014
    Arizona
    3
    Re: Pump won't run.
    I ordered a replacement run capacitor with the same specs(30UF, 370VAC, 50/60HZ). Old cap is an ECCOL II, PN: 628318-308. Most pool supply places i found online listed the cap for $35-45, i found the replacement on Amazon for $8.
    I removed the "hump" cover that's on top of the pump motor, and tested the cap. I didn't get any resistance reading besides 0, and nothing happened when I tried to discharge the cap, I even hooked it back up and attempted to start the pump in order to energize the cap, still didn't get an arc when I tried to discharge it.
    I also removed the pumps rear cap but I didn't notice a secondary capacitor anywhere.
    22,553
    Re: Pump won't run.
    Was it the new cap that you didn't get any reading on?
    Did you check the centrifugal contacts? They look like a "V" under the back cover.
    Mar 2014
    Arizona
    3
    Re: Pump won't run.
    Oh, no I'm sorry. I'm currently waiting for the new cap to arrive. The old cap was the one i didn't get any reading on. I just mentioned removing the pumps rear cover because I was looking for a second cap to test.
    22,553
    Re: Pump won't run.
    There should only be one and since you go no reading I bet the new cap fixes it.
