Thread: Adding warmth (solar, mesh safety, none)
    Feb 2012
    Maryland
    400
    Im sure this topic has been "covered" (ha ha) but I could not find anything.
    If water is 40, daytime temps are 60-70.
    What would facilitate warmth more.
    1. clear solar cover
    2. mesh safety cover
    3. uncovered for midday, solar at night
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Adding warmth (solar, mesh safety, none)
    Option #3. Solar covers work more like a lid on a pot, to keep heat in and slow down the rate of heat dissipation. They work really well when you use a heater to warm the water.
    If anything the mesh cover will work more as a shade on the pool and keep the water a little cooler.
    Love TFP? Become a
    TFP Supporter!
    38,242
    Likely option 3 is the best ... however, if you had a lot of wind or very low humidity, then keeping a clear cover on even during the day may be best as it lowers the loss to evaporation.
    Feb 2012
    Maryland
    400
    We actually have next to no wind, we are surrounded by 26 acres of woods.
    Humidity is certainly low, but should be coming up.
    Thanks!
