Thread: TA and CH showing funny colors
    Jan 2014
    Perth, Australia
    31
    Hi All,
    Using a Taylor K2006 test kit, always I get:
    • On TA tests the color changes more to pink rather than red
    • On CH the first color change is more pinkish rather than red, and the end color is not blue but more violet
    Is that normal? The color changes occur at reasonable values (TA 70-80, CH ~280), but it's just that the color is not right.
    Thanks!
    IG Fiberglass Pool - Sep/2013
    Pool capacity: 27,700 liter / 7,317 gallons
    Emaux V Series Sand Filters - Model: V700B; Size: 28"; Flow Rate: 89 gal/min
    Viron eVo P320 Pump; Flow rate (low/med/high): 32 gal/min, 56 gal/min, 66 gal/min
    Viron V18 pH Salt Chlorinator + RolaChem RP9 Automatic pH Controller
    Re: TA and CH showing funny colors
    I would like to know this answer as well. My results are like yours....never truly red or blue.
    Fiberglass Caged Pool Circa 1995
    15' x 32' - 16k Gallons
    Central, FL
    Hayward Cartridge Filter System
    38,290
    Could be chlorine interference or you have not reached the end point of the test. Are you adding drops until the last drop causes no further color change?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    The TA test final color is more like Barbie Pink than McDonalds Red. If you have high FC, it might go blue>yellow rather than green>pink.
    The CH test will go to sky blue eventually. Lavendar means you're getting close. Try another minute of shaking before you add more drops.
    38,290
    Also, the SpeedStir can help tremendously with the CH test.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You can also add two or three more drops of color indicator for more vivid colors at the end points. This is one of the few instances where you can vary from testing instructions.
    Agree on speedstir, it helps tremendously on all the tests.
    Essential Links:
