I cannot get enough pressure to the cleaner line to make the cleaner run at the recommended 28-32 rpm. Playing with the valves today, I closed the pool return line to see if the cleaner line would pick up the necessary pressure. It did. I don't want to run the return line closed all of the time for obvious reasons, so I have it partially open to hopefully balance the pressure between the two lines so the cleaner has enough pressure. I will post a pic of the setup soon. The return coming from the filter branches out to the pool return, spa return, waterfall, fountain, cleaner. I am just hoping I don't need to invest in a booster pump for the cleaner line. I will take a pic tomorrow and post. Thanks!
