Thread: Pump Blues
    Pump Blues
    Please allow I am a 1st time poster and not versed in proper rules I'm sure.
    My pump is 4.5 years old and had motor replaced a year ago. It seems to be working fine (2hp single sp pentair) I want a more efficient unit with programable timer for dummies.
    It is my understanding the var. speed is more expensive and I'm ok with that if it meets my needs. My kw/r is 12 cents give or take and I run all year but only swim during summer with no heater or h tub. These last few mo.s (Tx) have been costly with sub freezing temp.s for days at a time $$$$$. Is the VS pump worth the xtra or is a two speed gonna do it?
    18,000 gal in ground, 2 hp single speed, sand filter, 3 features, sports pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump Blues
    Welcome, 2 speed will likely be fine, in fact you can most likely retrofit yours with a 2 speed motor and external timer / switch to control it. (some 2 speed motors have a switch on the end of the cover, some require an external switch to change speeds). For mechanical timers we usually suggest intermatic brand timers.
    Ike
    p.s. what sort of features?
    Re: Pump Blues
    Many thanks Ike. We have 2 small waterfalls and 1 small bubbler. Your suggestions are well received. Replacing the motor only was not considered. My next chore will be acquiring a reputable tech to do the work. The market here presents limited options. And why my PB did not suggest a 2 speed is questionable, although it appears they did a good job with no prob.s to date. Thanks again.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump Blues
    So what part of Texas are you in? (putting region in your profile will help us give better advice, as conditions in the panhandle are different than the gulf coast, etc.
    Re: Pump Blues
    East Tx. Thanks Ike, my intentions are to polish my profile etc. and utilize this forum. My knowledge vs money spent building/maintaining the pool is inversely proportional at this time. I hope to improve on this.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pump Blues
    We all started with limited knowledge and built it up over time. I agree with Issac that a two-speed motor would be the way to go. Some places (such as my local Pinch-A-Penny) will allow you to bring your motor end in and will swap it over for a nominal fee, when you bring the replacement motor, or replace it free if you purchase the motor from them.
    Depends on your skill level and what you're comfortable with.
    At $0.12 a KWH the 2-speed makes the most sense. Use low when your just running the skimmer and no water features, high when you want the full shabang!
