Thread: PS-4, how to access AUX valves?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    I have a Aqua Logic PS-4 control panel/SWG. It has the 4 relays that it comes with used, I would like to add a 5th relay for a 2 speed pump. There is a socket labeled AUX Relays 3-6 on the circuit board. How do I get to those in the menu? I plugged a relay in and wanted to see if I could get it to come life, but no dice. I can switch the filter to 2 speed and when the filter is turned on it says High Speed and counts down or by pushing the Filter button again with go to low. Of course at that point the pump just turns off with no relay wiring installed. Any suggestions?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    May 2008
    Northern California
    71
    Re: PS-4, how to access AUX valves?
    I suspect they use the same circuit board for all variations of the PS series controllers. So that socket will probably only work if you had a PS-8 or PS-16. You would also probably need the correct firmware to access those relays. I ran out of relays when I added a two-speed motor a few months ago. I ended up adding a hi-lo speed switch and I just switch it manually. Not as convenient as an automated system, but I can live with it. The other option I considered was to put the lighting on a separate switch, but I like being able to switch the lighting with the wireless remote.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
