Results 1 to 10 of 10
Thread: Confusing TA readings
    Sep 2010
    SC Lowcountry
    54
    Using my Taylor 2105, I checked my TA today for the first time in awhile. TC was 8.5 (before adding bleach) and PH was 7.4. Using the 25ml method, I stopped adding the R 0009 at 30 drops. It never turned red. With the 10ml method it registered 50. Never had this happen before. I don't cover the pool during the winter, and adjusting the chlorine normally keeps it clear. Currently it's a little cloudy near the bottom (hence the reason I added bleach).
    Thanks
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    Re: Confusing TA readings
    If you used 50 drops using a 10ml sample, that would mean your TA is 1250??? That does seem unlikely, unless you just added 200 lbs of baking soda
    I suggest you test your fill water TA level and see what that is.
    Also, how old are your test kit reagents?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Run it again with ten, and see what you get. I'd do the fill water too as Jason suggests.
    If it were me, I would also double check the Cya, and CC reading to see what else might be going on.
    Essential Links:
    Sep 2010
    SC Lowcountry
    54
    Sorry I wasn't clear. Using the 10ml method it turned red with 2 drops.
    The test reagents are 3 yrs old.
    I would guess that you accidentally used a reagent other than r-0009.
    Support the site
    Sep 2010
    SC Lowcountry
    54
    Quote Originally Posted by JamesW View Post
    I've run the test 3 times with the correct reagents.
    Sep 2010
    SC Lowcountry
    54
    Just ran the TA test again using all new reagents. With the 25ml method, the water never turns red. I turns to a very pale orange. With the 10ml method, it turns very pale red with 2 drops, and very red with 3.
    I think that the color might be off due to a high chlorine level. The color goes from blue to yellow instead of green to red. I think that you're on the edge of the color change. Red plus yellow will give a more orange color.
    Try using an extra drop of r-0007 to neutralize the chlorine. Swirl for 5 seconds to allow the R-0007 to neutralize the chlorine.
    The change to orange or red should be correct. The reason that the color is more red using 10 ml is that 2 drops of r-0007 is equal to using 5 drops of r-0007 when using the 25 ml sample, which neutralizes more chlorine.
    Note that the k-2105 test kit is the bromine kit. Are you using chlorine or bromine.?
    Support the site
    Sep 2010
    SC Lowcountry
    54
    JamesW,
    The extra drop of r-0007 did the trick. TA is reading 60@ 25ml. BTW I'm using chlorine. We recently had a bunch of storms which dumped a bunch of organic material in the pool, so I added a 2 gallons of bleach to make sure I kept any algae at bay. Generally the water looks fine, but brushing the bottom after several days I get a greenish cloud. I just noticed the semi cloudy condition from the bottom up (roughly 2 feet) several days ago (hence the bleach).
    Thanks for the tip on the TA.
    Ok, good to know that it's working now. Aslo, be aware that the pH will read a false high in some cases of high fc. The fc needs to be under 10 ppm to get a reliable color.
    Support the site
