Results 1 to 15 of 15
Thread: Adding Winter Chlorine
    Merged thread with "raising chlorine without a pump" thread. To avoid confusion please do not start a second thread on the same topic. Zea3
    I live in a cold climate and my pool is winterized. the ice is melting off my cover and I just looked under the cover, water is clear. I tested my chlorine and the levels are only 0.8. How do I add chlorine if there is no circulation? my husband suggested using our sump pump that we use to remove the water off our cover.
    21k inground pool
    thanks
    Moved from Announcement forum to Just Getting Started. Brushpup.
    Last edited by zea3; 03-10-2014 at 09:00 AM. Reason: merged threads with identical topics
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    adding winter chlorine
    What is your water temp ? Algae has a hard time forming in cold water temps. Not to say that it can't happen.
    If your water temp is really cold I would think you would be ok till you open. Just make sure you get things going before the water temp hits 60.
    Jeff
    Re: adding winter chlorine
    A covered (opaque cover) and winterized pool should not need chlorine added. All you usually need to do is open the pool before the water gets much above 50 degrees and you will be fine.
    If you have a mesh cover, adding some chlorine is a good idea.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Adding Winter Chlorine
    Welcome to the forum dreon!
    Essential Links:
    just melted the last of the ice off my cover this week but we wont be able to open for another 4-6 wks. tested the water and my chlorine is less than 1. water is clear.
    how do you add chlorine without a pump to circulate? My husband suggested throwing in our sump pump that we use for removing the water off our cover?
    thanks a bunch for the reply. My cover is opaque. My thermometer is in the back of our pool shed and it was too cold to search for. The water temp is only estimated by my hand to be in the mid 30s. I am jealous about the other posters who are in the 80s!! We thought we were in a heat wave today as the outside temp hit 50. sorry if I double posted this forum.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Re: raising chlorine without a pump
    I use a canoe paddle, but that's for a hot tub -- a submersible pump would sure be a lot less work.
    If you can walk around the pool I imagine that diluting the chlorine a lot and distributing it around the pool would help too. When I'm adding ~6 oz of bleach to my hot tub I typically add it to a bucket with a few gallons of water and "pour it all around"...
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    bridgman's Avatar
    Mar 2014
    461
    When my pool thermometer breaks I can usually find some kind of thermometer that covers the temperature range either in the kitchen or around the barbeque...
    If it makes you feel any better it was 17F and snowing here today.
    Agreed. My barbecue thermometer (Thermapen) works great. 2 second read.
    11K gal, IG plaster, Pentair 011018 IntelliFlo 3HP Variable Speed, 4 cartridge filter, The Pool Cleaner, Heliocol Solar heating
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's a lot of work but you can brush the pool too. The pump won't move a lot of water but will help a good deal. If it were mine, I would agitate it as much as possible by brushing or doing something similar.
    Essential Links:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    X2 what Brushpup said. Brush the sides down.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    dreon:
    You've already been given great advice, so I will take this opportunity to welcome you to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    As far as circulating the chlorine without a pump, it's pretty much what the others have said. In fact, here's a thread from a user who was without power for over a week in 90-100+F temperatures. Kept their pool clean by manually circulating and swimming to churn and circulate the water. User was diligent in maintaining the proper chlorine level. http://www.troublefreepool.com/threa...void-a-problem!!
    bridgman's Avatar
    Mar 2014
    461
    Quote Originally Posted by BoDarville View Post
    Sounds like a plan. Since the water temperature was estimated at 40F they'll be swimming really really fast to stay warm
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Quote Originally Posted by Dustin1047 View Post
    Duh~<slaps forehead> Why have I never thought of this before!?!? Thanks for the idea
