Results 1 to 7 of 7
Thread: Sand Drain Leak, TR140
    Mar 2014
    Tucson
    3
    I have replaced the Sand (925 lbs) in a Tr140. Removed the sand by removing the sand drain and backwashing. While removing the sand drain, I had stripped the threads on the sand drain part by not realizing it had reverse threads. The threads on the fiberglass tank look good, not striped out. So I replaced the striped out sand drain part, using pool grease on the o- ring and plumbers tape on the cap threads. Now I have drip at the 2.25 in nut where the o-ring is compressed againt the tank. Do not want to remove the sand. Should I just tighted a bit more? I have drained the water from the tank. Thinking about backing the fitting out far enoungh to wrap the threads with plumbers tape and adding some silicone. Afraid to remove complety, out of fear of notbeing able to push back thru 925 lbs of sand. Has anyone out there experienced something like this? Any tips?
    Mar 2014
    Tucson
    3
    Threads merged. Please don't multiple post. Bama
    22,537
    Re: Sand Drain Leak, TR140
    That's a sticky wicket alright.
    I'd probably just try tightening it a little before anything else.
    Mar 2014
    Tucson
    3
    Had to try tightening up a bit. Sure enough, you were right. Thats all it needed. No leak!
    22,537
    Thanks for posting back that it worked.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    +1...sometimes we never hear back. Good suggestion Bama, that's what I call the Sling Blade approach.
    Essential Links:
    30,400
    Overtightening will likely make matters worse. Silicone caulk is probably worse?
    Can you make a Gasket out of rubber to fill the void? Plumbers thread sealant is often a good choice on a large gasket like that.
