Thread: Stenner Pump in Freezing Temps
    Sep 2013
    Dallas/Fort Worth
    21
    I just installed my stenner/pump combo a few weeks ago. I bought the 120 volt version and chose to install it (in terms of electrical) via an in-use plug that is wired to my timer, rather than cut the plug off and wiring it directly to the timer. I did this because I was under the impression that I shouldn't leave the pump out in freezing conditions (I wanted to be able to simply unplug the unit instead of having to mess with the wiring at the timer). Having said that, it appears that most people who purchase the 120 volt models simply cut the plug off and hard-wire them directly to their timers. I would think this would make it difficult to take the unit out of the elements when the temp drops. Do most people leave their pumps outside all year long, even in cold regions of the country?
    Dallas, TX. 27,000 gallon in-ground free-form gunite. Built in 2007. DEL60 filter with single speed 2hp Hayward pump. Polaris 360 cleaner with associated booster pump. Stenner chlorine pump and tank. Intermatic P1353ME timer.
    Re: Stenner Pump in Freezing Temps
    The pump can be left out in the cold if you remove the feed tube (and empty the storage tank). Removal and replacement of the tube are both fairly easy, and many people replace the feed tube annually anyway. On the other hand, there is nothing wrong with using a socket and bringing the whole pump inside.
    22,553
    If you run the pump dry you can leave it out, however, very cold weather does affect the elasticity of the pump tube so, as Jason said, it's a good idea to bring it in.
