Thread: Replacement Intellichlor IC40
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Hey guys, I am getting my replacement Intellichlor IC40 soon. My current one stopped producing chlorine towards the end of last pool season. Since then, I was using liquid chlorine at the end of season and all winter/spring to maintain FC levels. Is there anything I should know about the water chemistry when I go to install the new replacement cell? I would think that even though there was no conversion of salt to chlorine in the past several months, that doesn't really alter the water chemistry and my new cell will start producing chlorine the same way as before. I don't need to add anything (like a new round of salt)? Thanks
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Re: Replacement Intellichlor IC40
    You might well need to make small adjustments to both the salt and CYA levels, but things should still be basically where you want them. If you post a full set of water test results we can give you more specific advice.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Took the water over to the pool store for the salt reading, 3700, which is good for the Intellichlor. Other numbers look good. I would assume nothing more is needed to do for chemistry w/ installing the new IC 40.
    Other numbers:
    FC 5
    pH: 7.4
    TA: 80
    CYA: 70
