Thread: In ground hot tub jet wall fitting came unglued
    Jan 2011
    Richmond, Texas
    595
    I now have two hot tub jet wall fittings that have come loose. They are waterway wall fittings and look like they glue onto a 1 inch pvc pipe in the back. Can I just empty my hot tub and glue these back into place? Any type of special glue I should use? Here is a link to the type of fitting. http://www.poolpartsonline.com/p-248...ly-gunite.aspx
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    22,548
    Re: In ground hot tub jet wall fitting came unglued
    You should be able to just glue them back into place. I'd use all purpose cement on them, though they're probably just PVC.
