Thread: Raypak propane heater malfunction
    Mar 2012
    Tampa Bay, Florida
    166
    This morning I went to raise the temperature on my 8 month old propane heater and the display doesn't work. The screen brightens when the on/off button is turned on, but there are no numbers to be seen. I have no temperature reading, no indication of mode, no way to view diagnostic codes, etc. Otherwise I can get the heater to come on and can raise the temperature to an unknown amount, but I'm basically blind to any settings.
    Anybody hear of this happening and recommended solutions? I doubt that the warranty goes beyond 6 months, but I'm still investigating that.
    I'd appreciate any suggestions.
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Raypak propane heater malfunction
    Sorry I don't but we have some equipment guys that will likely post and help you out on this.
    Essential Links:
    Mar 2012
    Tampa Bay, Florida
    166
    After researching the Internet, I am suspecting that the display unit failed which is a sub-board of the main control board. Monday, there is supposed to be someone coming out to look at it.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by hoosierrun View Post
    You are correct. It's just the display board.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
