Thread: Umbrella Holders?
    Aug 2011
    Middle TN
    83
    Umbrella Holders?
    So I've seen where people make umbrella holders to put into the deck while it's being poured. Seems like a common solution to that is DIY pvc pipe with a screw in cover. I was wondering if anyone knows someplace you can just buy umbrella holders to put in the deck? Ideally I'd like the ones that have the brass caps but I'd be interested in any places ya'll are aware of.
    On a semi unrelated sidenote, those big cantilever umbrellas seem like they always have a 4 bolt pattern that ties them to their bases. Has anyone set bolts sleeves or something similar to be able to bolt one of those onto the deck later? Thanks!
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    Apr 2012
    Mason, Ohio
    119
    Re: Umbrella Holders?
    My pool builder used the same brass cups that they used for the handrails. They don't have covers, but still work well holding umbrellas (or volleyball nets).
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    Apr 2010
    Buckeye, AZ 85326
    619
    I thought about adding more umbrella sleeves to my deck but its kind of pricey to do it after the fact. During my research I found this place along with several others that sell the PVC style sleeves.
    http://azwholesalepoolequipment.com/...LE_HOLDER_.htm
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    JoshU's Avatar
    New Orleans, LA
    543
    Waterway makes plastic umbrella holders in several different colors. They include a deck cap.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    The ones I bought are actually three parts. The main body that gets buried in the concrete right up to the top. Then an insert that drops in with a lip on the top to give nice finish look on top. That insert is threaded and the screw-in cap goes inside of that. I wish however that they were a few inches deeper. I also ended up drilling a hole in the bottom of each one down through to the stone below the concrete because otherwise they get filled up with water. I just use the caps for winter.
    In the end, it is often too windy here (or an occasional gust) that lifts the umbrellas out of the holder and that's a problem. So it limits there use for me. But I'm glad they are there.
    Ours are the Waterway version mentioned above.
    An ideal solution to the wind issue would be to make my own (thought it's too late) and have the top part of the body be threaded. Then I'd have a threaded part that screws into it that and extends up a couple of inches. Then when I dropped the umbrella down into the hole, I'd drill a hole through the umbrella pole and also through the screwed in piece. Through that hole I'd put a clevis pin with an attached round spring clip. It would take a few more seconds to put that in place, but it would have been worth it for me to fix the wind issue.
    The Waterway ones are around $11.00 "limited time" price at poolpartsonline.com at the moment I just saw. And as also mentioned, they have several colors available. I put in about a dozen. They only cost me the material I bought, the PB didn't charge since it's just a few extra minutes to put them in when doing the concrete.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    That's great info about the wind for the umbrella holder, bmoreswim. My PB is supposed to include a dozen gray umbrella holders (I sent him some links to order, he said they usually put plain pieces of PVC in the ground), but it sounds like I should try to DIY or hack something that will take an extension before we pour our concrete. Here in OK - wind is definitely a concern.
    Do you know the diameter of the sleeve and do you think a plumbing supply place would be the right place to go for parts? From what I understand, I'd be sacrificing the "color match" to our gray deck but it would probably be worth it to actually be able to use it! Our old above-ground umbrella holder heavy-duty base had me clutching the umbrella pole in every mild gust, so I don't want the much-desired umbrella holders to be a bust.
    ETA: I found this link describing one DIY version, with 1.5 sched 40 PVC, but am guessing I would need to upsize the initial piping and step down to 1.5 as the "above ground" extension that gives the stability and ability to pin through the umbrella pole. Wondering if I should look for some kind of metal alternative (maybe stainless steel for outdoors?), since pvc could crack if stressed too much by the wind, I bet. http://www.troublefreepool.com/threa...sylvania/page2
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
