Thread: Pool Math Question VS Recommended SWG Level Article
    Jan 2014
    Naples, FL
    36
    Hello,
    Easy question. One of the first articles I ever read on TFP was the "Recommended Levels for SWG" and I've been targeting those readings to a tee. When I enter in my readings which are :
    FC = 6.0
    CC = 0
    pH = 7.5
    CYA = 70
    CH = 300
    ALK = 70
    In addition, I also select Type of Pool = Plaster, Chlorine Source = SWG and Method, of course = Trouble Free Pool.
    Here's my question, it says my target FC on Pool Math should be 5-10 but the article says 3-5. The reason I ask is, I've been trying to dial in my % on the Salt Water Generator so it doesn't produce more than 5.0. However, if 5-10 is the way to go, then I could stop driving myself nuts with adjusting the run time, etc.
    The other question, and this might not be worth worrying about but, CSI. I am guessing that the number Pool Math generates for Target Level, I want to stay at or as close to as possible as that Target Number correct?
    Thanks everyone for your help!
    Size and Type : IGP, 7500 Gallons
    Finish: Wet Edge Satin Matrix Finish (pebble), Cartridge: Unicel Model C-8409, 12 PSi, Pump: 1.5 HP A.O. Smith Model USQ1152 (not sure if it's two speed or variable), Pool Date Remodel: May 2009, Accessories: SWG Auto Pilot Digital Nano Model 75041, Rock Waterfall
    Re: Pool Math Question VS Recommended SWG Level Article
    Pool Math has some default target levels, but they are generic and not optimized for a SWG pool. Take the target levels from the SWG article (or the correct table in Pool School) and plug them into Pool Math. That is the same thing that is happening with FC target level, you are getting the non-SWG FC target from Pool Math, instead of the SWG targets.
    It is really best to completely ignore CSI unless you have one of the rare situations that make it important, like uncontrollably high CH levels.
    Jan 2014
    Naples, FL
    36
    Thank you Jason!! I will stick to the article and ignore CSI!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    The CSI number I feel is more important with a SWCG. That number will give an indication of how quickly your SWCG Cell may need cleaning due to calcium build up. I tend to run a slightly negative CSI and have not needed to clean my cell. It's a clear housing and I can see the cell.
    Living in Florida you're more than likely need to increase your pump run time in the summer and lower it in the winter for max energy savings.
