My system is setup to change a value when the heaters on, and change it back when the heater's off. To save energy, I'd like to have my Intelliflo change speeds, too. For example, I run my Intelliflo at 1000 RPM (140W) normally; however, I need to bump it up to 2350 RPM (890W) when the heater's on (to create enough flow). Currently, I manually bump the pump up when I turn the heater on, which means the pump runs at this expensive rate much longer than it needs to.
Is there a way to program my Easytouch such that the heater can bump up (or down) the pump speed when it's on or off? I didn't see anything mentioned in the manual, off hand.
